Fixed yoke np208......or.....NP208 SYE kit
jt512
Maryland
Pass side drop 27spline 208 that I built using a dodge output shaft and redrilled back half. I built this to use in the Willys im building but ended up changing to a driver side diff so I went with a later model 241. This had been behind a th350 using a fitzall spacer then after the sye it was mounted to a 700 trans. There is a thread in the garage posted by "twoslowfor50" about this conversion and has some pics I had posted of mine as well. Asking $250 for it, located at 21230 Baltimore, not sure about shipping, I never tried with something that wont ship flatrate.
http://coloradok5.com/forums/showthread.php?t=246154&highlight=208&page=5
My pics are post 46
Just a thought, I could also disassemble this and sell it as a SYE kit to someone. I would send you the output, the back half of the case, the fixed yoke, and tail cone .......you could then simply install it all onto your 208. It would be much easier to ship as well.
You've got me thinking... I just wonder what the rear driveshaft would cost me.
Cheapest way would be to find a rear shaft from a pickup that had a fixed yoke
and have it shortened.
I just realized this is the wrong spline count for me, because I have the sm465 I should be a 32 spline.
What is the speedometer connection for this? Same as GM?
Sorry about the delayed response :doah:
It is a cable drive, it's the dodge speedo housing, cable appears to be the same size as a GM. I never drove the rig with the setup, it's still never been driven with the new setup :D
Josh if this isn't gone by the hillbilly party. I may buy it from you if u bring it along
