There are 3 front output styles: 10 spline, 30 spline, and 32 spline.
The chevy 10 splines seem to be 77 and earlier with a 1310 cv yoke front output. i have yet to see a flat flange for a 10 spline front output in the junkyards.
The chevy 205's from 77 ish up have a flat flange and that will be a 30 spline front output. i have yet to see a yoke front that is 30 spline in the junkyards.. I'm would think you could get 10spline flat flanges or 30 spline cv yokes, but i've never seen them from the factory.
Ford 205's and some dodge 205's have a 32 spline front output, usually comes with a bigger 1330 yoke, not a flat flange. but like scott said you can use a 32 spline 208 flange or whatever for that ford front output shaft in your 205.
For my setup i pulled an older ford f250 np205 front output, 1330 yoke, and front driveshaft.. then i chopped, shortened and rewelded the front driveshaft back together to make it the correct length for my k5. just make sure you get the indexing right for the ujoints and make sure its pretty straight before you weld it up. i didn't even balance it, and i've spun it close to 60mph in the sand without a problem.
