After going cross eyed in the search engine and running out of time I need to ask y'all this question.
I was towing a medium uhaul trailer in my 89 sub from Ga to Chicago and blew my yoke seal. I win the sucker award for not knowing enough about my own truck and its axles. I was away from my home, tools, manuals, etc. and needed to have it fixed at a shop. 900 bucks later I have this awful pit in my stomach feeling I got reamed.
Now truck is back and Ga. and my drivers side rear outer seal blew. I took it to a mechanic and he is saying about 400 if I just get the offset bearing. My sub is sitting now b/c of my lack of money and axle experience.
I have the service manual for this truck - I need to fix this myself - I need to know how to work on my own truck
Here are my questions:
- Section 4B1 of service manual REAR AXLE -Just to be sure the 10 bolt is a semi floating 8 1/2 RG This would help to know which section to start from - Geez I feel like a idiot but am willing to learn
- Can I get by with a slide hammer and bearing remover from a place like O'Reilly's? Where do I get the bearing and seal installer? Can I get by (and I'll use this term loosely) beating the bearing back in with a socket large enough?
- To get the axle out I have to take the diff cover off right? The manual says I need to remove from the carrier a lock screw, then diff pinion shaft, then the c-lock from thrust block, and then the shaft slides out right?
(You gotta do all this on the trail if you snap a shaft????)
- What else am I missing? Going ahead and say screw it and just swap in 44/14bff's???
I just think I am upside down in this axle now. Been looking through CL all day today for axles and people are asking a lot for them around here. Seems not matter which way I turn I am going to drop some money i.e. cash for tools I don't have or cash for a used axle or pay someone to do it and be done with it?
- Do I need a press to put new bearing back in
