A trick an old timer taught me that helps is to use something to prop up the rear of the hood slightly,like a rubber eraser or piece of heater hose,so the rubber seal between the cowl and hood wont seal,this lets heat from the engine and radiator fan blow back onto the windshield..
On my '71 GMC plow truck, it had lost the rubber seal long ago,and the hood was slightly bent up in the rear,like someone shut it when something was in the cowl area ,so that didn't have much problems with snow build up,plus the heater in that thing just about threw flames !..
I had to do that a few times during our nasty Nor'easters that often have 3+" per hour snowfall rates and 60+ mph winds--my diesel plow truck wont always blow hot when its idling or run slow,but will when you start pushing snow and load it down.....but every trick in the book doesn't always prevent you from having to get out,and manually remove the snow build up sometimes,under those extreme conditions !..
). And, as Can Can said, snow below the wipers is normal during the winter months. That shouldn't cause the rest of the windshield to frost over.
