I tried to flare the end of my fuel line with a double flare. It turned out great except that Ithink the lip is to sharp. I attach rubber hose to it and the hose seams it gets threaded and sheads when I attempt to put the fuel line inside it.
http://www.corvette-101.com/flarenut.htm
It seams the double flairs are for nuts not hose.
The flair is not the same as the OEM flair GM did.
thoughts?
How do you guys make your flairs?
thoughts?
got mine when thay first comeout at just under 500 bucks tho. but i am not unhappy at all.
