i am ready to make my crossmember for my 4l80-e/203/205 doubler kit. its in a 1ton frame and i have the 205 up rotation of 2".
my question is should my tranny pan be level with every thing hanging in its correct position. or should it be tilted up or down.
my reason for the question is i figured with the deeper frame hight of the 1ton frame and 2" up rotation it should be perfect for a flat belly pan . but i have found i am still a little down at the 205 tcase bottom for the front output. so i was thinking if i made the crossmember to hold it up so it was flat then perfect. but thats when i found this problem.
thanks for any help or pics. and yes i have seen tons of pics for the crossmebers and got lots of ideas.
Looks like I need to work on my posting skills
