"Flat" Chevy Trans Crossmember - $100 Mid TN
truck-oholic
Monrovia, IN
This came out of my 77 K5 Blazer with a TH350/NP203 combo. Thought I might use it for my SM465/203/205 setup but decided to make my own custom cradle style crossmembers instead. This is the "flat" style crossmember that is designed to use the two piece "C" bushing mounts from pre-1985. You should be able to modify this crossmember fairly easily to accept the 1985 and newer monoblock type bushing mount if so desired. I will go ahead and include the stock mounting hardware (bolts & spacers) with the crossmember for no additional charge.
Going rate for these is $100 so that is what I am selling it for. May do some trading on offroad related stuff.
Location is Spring Hill, TN 37174
Thanks,
Jesse
610 999 1546
