Flat Top Knuckles L&R for D44/10 bolt
bmsmalley
Montgomery, Texas
I have a set of flat top knuckles (left and right) for Dana 44 or GM 10 bolt. Right knuckle has already been milled, drilled and tapped.
200.00 OBO plus shipping. PM or call 936-203-8304
ODU knuckle new $179.00
WFO new $219.00
ORD new $219.00
so you might get some bites around $125.00
anyhow bump for you
Well, seeing as someone posted that up, i was gonna offer 125 shipped and see what you thought. Dont really need them, but will eventually.
Thoose prices are for the flat top knuckle (1 piece) so arent you suppose to run the 2 matching ones from the same axle
You need matching cause of the tie rod taper. D44 goes in from one side and 10 bolt go in for the other side (one is top mount other is bottom mount). Other than that, you only need the one side machined for CROSSOVER. High steer requires both sides.
pmed you asking for your paypal. Never got anything back. I can send money now, but ill be going to work in 30 so if not now then at 10pm central.
