MrDJ
DJ404564X4
I used to flat tow my Jeep all over the place. Is it possible to flat tow my Blazer?
Don't have a trailer for KOH about a hour tow each way.
I managed to scrounge up a rough loaner tow rig for the week. Might have to sleep inside it.
Yeah I think when it comes to towing I would definitely pull the rear driveshaft and if you don't have manual hubs then I'd pull the front as well. Axle bearings usually last a long long time but running the transfer case in N and towing it anything more than a short distance may cause some erratic issues with the transfer case depending on the type of T-Case. Not sure what you are running
