Flat towing a m1008
84CUCV
3/4 ton status
NJ for now
will be going about a hour ride back up. the 60 kingpins need to be rebuilt. will be pulling it with my m1031. will the king pins cause a problem? i was just going to hook it up, put the 208 in Neutral and go or maybe i should drop the drive shaft?
thanks for the help
Should be fine...
Unhook the driveshaft (I would just wire the axle end up to the frame after taping the u-joint), put in neutral, and unlock the steering.
