Flex-a-lite fan kit-good?
Yeah. They will work. But it is one hell of a lot cheaper to go to a wrecking yard and get a Tarus or Windstar, fan. They move more CFMs and work better.
Well, I'm leaning more toward a kit of some sort-that way it just bolts directly in with no complications. Wouldn't one have to make their own brackets to use the Taurus fan set up? Any other kits that might be a good idea, or is the Taurus fan swap pretty straight forward? Seems like the flex-a-lite would be a good way to go since it's bolt-in!? Thanks!
I think theres an article in the tech section on the Ford Windstar fan install, it sounds like about the easiest swap of commonly available and cheap factory parts.
Eh, I was single, still in hs, working two jobs. My '64 was the only thing I had to spend money on. At the time a fan was important. I tried a $20 Auto Zone special, but it sucked. I thought a fan was a fan was a fan. Not so. It's such a forgotten item, but try running w/o one. Kind of like breathing. You never think it's all that important until you try not doing it.
I've never messed with electric fans before this so, y'all will have to excuse my stupidity here!:doah:I see all the wiring kits to get the fan to turn on when a certain temp is reached and off when temp drops and what-not, makes sense, easy/automatic. But, would there be any harm in just running them manually switched and just keeping an eye on the temp gauge? Seems like it sure would make wiring a breeze, just requires paying more attention. Would there be any harm in that idea?:confused:
It's not bad per say to run the fans on a manual switch, but it's not really practical IMO. It is not a good idea to run them constantly on, that throws a bunch of issues into the mix.
You'll be surprised how often they will cycle on you, my single fan comes on for maybe 2 minutes, then off, then back on if idling or crawling. It's not something you want to mess with, and the wiring is not that complex at all. If a temp switch is complex, stick with the clutch fan.
