Flex plate starter problem
mason72
Registered Member
tucson az
My buddy got this 63 waggy about a year and a half ago. It has a full Chevy drivetrain. 350/700r4/208 8 lug 44 semi float 14 Chevy leafs.
I went with him to check it out and buy it. Starter sounded great and about 20-25 starts later the starter starts to grind. Another 10 or 15 starts and it won't even turn the motor over. He dealt with it for a while and and would carry a spare starter and we would swap it out real quick on the side of a trail. The teeth on the flex plate we're pretty chewed up and would eat up a starter pretty quickly. I assumed that somebody just dealt with poorly aligned starters for so long that it damaged the flexplate. A year or so of that I got sick of it and brought it over to my house put a new flex plate and starter in it. I shimmed the starter multiple times to get it as perfect as possible. Everything was great for about 5 or 6 months and then it starts grinding again.
So my question is, is there any difference between any year flex plate and starter between early '70s to late '80s.
Thanks Sean
So it's sounds like the starter is moving. The correct starter bolts are important to keep the starter from moving. Also in the 70's GM used a brace on the rear of the starter to help keep it in on place. the flex plate for gen 1 sbc is the same except for balance. 700r4 uses the same flexplate as th350
this true for the starters. the 153 is smaller in diameter and uses 10 3/4" torque converter. Not what I would expect in an off road truck. 168 is 11.5" torque converter
I'll check that stuff out. Thanks.
I never knew about the bolts.
Are you shimming the starter farther away from the flexplate, or shimming the outside bolt to get it closer to the flexplate?
153 tooth count vs 168 tooth count.
153 should use a straight bolt pattern starter.
168 should use an angled bolt pattern starter.
I am using a 168-tooth flex plate on my rig with a mini-high torque starter, which are all straight bolt pattern. Been using it for years with no problem. My truck has a small block 350 with a 4L80E trans wich has the larger 11.5" torque converter. My truck did originally come with an angled bolt pattern starter. Maybe the gear reduction mini high-torque starter is a different deal than the old non-gear reduction stock GM starter.
If I remember correctly I shimmed the inner bolt moving it away.
Isn't the TC diameter a function of its stall speed? i.e., higher stall speed = smaller TC
I believe so in general. I'm sure there are exceptions to that rule.
