nosman778
Registered Member
on my 77 k5 when i flex just alittle the fan runs into the shroud and i was wondering what yall think it could be and do i really need a fan shroud??? if so will a flex fan solve this problem
Go electric.
Or box and brace your frame.
motor mounts
see i was thinking electric. does it make that humming sound while running![]()
this is the picture right before it happend on that little of incline..
like yeah it shouldnt rub on that lil bit..
for me.. my front clip came off of a truck with a BB... (1987).... and having a SB in it... the fan doesnt sit in the shroud... i was told due to motor mount placement or something... this is the reason... so ya have to watch your fingers when you have it running and your under the hood...
no overheating problems...
but my wife drives it and says everything is good just the oil pressure drops everynow and then... would it affect anything if i just take the shroud out???it'll run hotter, yes the shroud works that well.
I had issues with another truck i had running hot without the shroud on it, always got hotter the longer i drove it on eht freeways too, idling, it'll heat up too.
Leave the shroud on and just be aware of the problem until you get those mounts replaced.
I mentioned the motor mounts as i have had the same issue in my Burb, slightest little twist, and i mean street curb height, would let the fan start rubbing the lower part of the shroud. Checked and saw flat motor mounts, replaced them and doesn't do it anymore.
thanks again.I havent had a shroud forever. I have a 2" body lift. It gets 110*+ around here and never overheated. But you should have one.
dont run a flex fan. they explode.
I had one that the blades came apart at about 4500rpms. shattered my fan shroud and sent peices into my radiator.
Just go to the junkyard and get a stock replacement clutch fan, or go electric
I also had overheating problems with the burb a few years back too because i wasn't running a shroud. trying to leave Cali, climbing up the hills leaving Indio, CA. i was forced to run with full heater on to try to help with overheating. the motor was climbing up and near the 250 mark the longer i went. Of course i was pulling a trailer with some a dually bed on it, but still, had to slow down to a 30mph crawl, go easy on the throttle in thehopes of not blowing anything up. I made it, but from then on out, i noticed around city driving i would get some valvetrain clatter when alittle harder on the throttle.
I didn't have the shroud on this time, because i had recently installed a 4 core radiator, i hadn't gotten around to modifying the one i had to fit right. After this trip, i did that week though, modify it and install it.
No cooing issues to this date with it, actually NOW i am having issues with it running TOO cold, i have the truck setup for heavy duty cooling with a 4 row radiator, heavy duty fan clutch and it takes forever to get to t-stat rating, and then when it does open, it cools it down a ton.
I tried running electric fans in the past on other vehicles, and even the Burb once, i personally was never too fond of it in the truck application though, there are times i tend to work the engines like they're supposed to be worked in a truck, and really, IMO, the engine driven fan works the best for it.
and yeah, i HATED those flex fans, ran a few of them, not for very long though.
