I can't find these on rock auto and I find multiple lengths on Jegs and Summit. Anyone know the right length and thread pitch? I have to do the th400 to 700r4 swap a the hobby shop on base and I don't have the option to chase down parts.
If he is swapping a TH400 for a 700R4,wouldn't they both use the same flex plate ?...sure he's not looking for torque converter bolts,not the bolts holding the flexplate to the crank ?...
I'm confused..
I have multiple sets of flexplate and flywheel bolts sitting in my scrap pile. All of them are 6-sided fine-thread bolts. If you need exact measurements let me know.
TH400 and TH700R4 will use the same flex plate and the same flex plate bolts.
When I went from the 700r4 to the th400 I had to swap flexplates, the torque converter bolt patterns were different. Now that I’m going back I want new bolts. I found the part# and ordered a set.
