pismorat
I searched the forum and have Googled myself to death on this...but cannot find the solution to the problem I am having with my floor jack. I had the front of my truck lifted about 1" off the ground and was getting the jack stands ready when the thing just released all at once and dropped the truck (tires still on). It then wouldn't pump up at all, so I assume something is wrong in the release valve area. I took the whole thing apart and found an aluminum washer/seal under the release valve housing (pipe threads) that I think is the issue. Problem is I cannot find a way to fix this thing...should I just cut my loses and get a new one?
