I have the standard cracks in the floor and plan on welding the cracks then putting a small section of steel over where the crack was and stitch welding that piece in place to help spread the load. It will be my first crack repair.
Can you guys walk me through the steps?
I know I need to drill holes at the end of the cracks but dont know how big of a bit to use.
Then grind a V groove to the best of my ability. Then spray with brake clean and wipe dry. Next I start to weld the crack? Can I just wekd from the top or do I NEED to weld it from both sides?
Where do I clamp my ground to? Anything I need to worry about?
What about the under coating and grease and stuff on the bottom of the tub?
