Got any pics of it finished?
Floor supports were welded, I used panel adhesive to attach pan to supports with sheet metal screws in a few spots to hold the pieces tight metal to metal, the screws have been removed, if preped right the floor patch should stay put.I'm going to weld it in place along with duplicating the factory spot welds on the bracing. Is panel adhesive strong enough to keep the patch in place as the body flexes? Why not weld like the rest?
