Floor shifter?
Bullet
Abilene, Texas
Saw a Blazer today that was an auto w/ a Hurst Floor shifter. Looked awesome and was easy to reach without bending over too or at all to shift. I'm sure that it WAS NOT a manual valvebody. Has anybody done this or have pics and info on it??? /forums/images/graemlins/ears.gif
BTW, I have a 700R4 tranny with a stock valvebody
I installed a floor shifter in mine. It was easy to install and is easy to reach....hold on and Ill take a picture of it.
Thats the best I can do tonight. I still have to install the trim. Its a z-gate shifter and I will never own another one, they suck for wheeling/street use.
I have the B&M Quicksilver right beside my seat in easy reach. I am building a center console around it so no pics yet.
[ QUOTE ]
[/ QUOTE ] I really like the B&M Starshifter. They look just like the Megashifter, but are more street friendly to use. B&M Starshifter
I have the Star Shifter which I am installing in the next day or so. Trying to find some brackets to adapt a cable shifter. They were very common on Firebirds and Camaro's.
They are very easy to convert. Basically mount the shifter, run the cable, and pull off the old linkage.
Did you leave the stock column shifter in place? Or did you modify to control the radio volume or something?
It is a simple bolt on installation. You have to remove 2 transmission pan bolts and install a bracket to hold the cable. Then drill a 1" hole for the cable to go through and 4 bolt holes for the shifter its self and then adjust the cable. The stock shifter arm is held in place by a pin that can be driven out with a drift and hammer. I hooked my reverse lights up to some rear facing flood lights and run them off of a toggle so I dont have a reverse light wire hanging around, but it comes with a switch and you could hide the wire under the carpet if you have carpeting (unlike me /forums/images/graemlins/grin.gif )
Doesn't really server a purpose other than looks, does it? I still might do it, but not this week...Anybody think of another reason?
I have a manual valve body so I have to use a floor shifter. For a more normal vehicle the floor shifter does the same thing as a column shifter but looks better IMO.
Less linkage to deal w/ during a body lift, assuming the new new shifter controls the trans and not the stock linkage. The stock floor shifter on my old M/C SS just worked the normal column linkage, what a waste-typical GM /forums/images/graemlins/rolleyes.gif
It does serve a purpose, but how much depends. Shifts are more positive. You get features like reverse lock-out and such so you don't miss-shift when in panic mode. You can change shift paterns like reverse-manual valve bodies. And probably most important for GM's flexy frames, you have less problems with getting it into the right gear, and keeping it there. With the column shift, the flex can be bad enough (especially with bad mounts) to actually change gears on you or even bind it up till you can't shift at all (or so I'm told, never experienced that one).
