SafetyHelmet
Registered Member
Hey guys! I figured I would do this as a post rather than PMing a few of our resident experts, so that hopefully others can learn from it too.
I've finally been doing some MIG welding. I love it. I realize it's probably not fun to do 10 hours a day for a job, but I sure have a great time practicing at it.
Anyways, after I do a few more trial runs with tacking sheet metal together, I think I will be ready to patch up some rust holes in the floor of my K5.
Here are my questions:
1. After I weld (via lots of tacks instead of a bead), my plan is to grind them down smooth with a grinder, flap wheel, and maybe wire wheel. Is there anything else I should do to treat or prep the welded areas before applying Zinc Chromate primer?
2. After the above steps, I plan on priming the underside as well. Should I use paint over the primer, or should I go right to the spray on underbody coating? I have some 3M rubberized stuff that I have had good luck with. Used it to quiet down my welding cart trays. Worked like a charm!
3. For the interior, I'm removing all of the rust and paint on the floors, and am going to re-prime, and then roll on Herculiner (or an alternative if someone has a better recommendation). Do I need to paint first, or can I put herculiner right on primer? What's gonna last longest / prevent rust the best?
4. I don't want to muss up the exterior just yet, but some areas appear to have some rust under the paint, and I'd rather drive around with primer spots than let it rust further. Should I put anything over the zinc chromate primer if I fix these, since I won't be repainting for at least 2-3 more years?
Thanks again. I hope you guys know how valuable your experience is to others!
