Floorboard patch panel
Stickseler
3/4 ton status
Northern Virginia
Is this the elusive under seat floorbord patch panel?? Its to cold to go outside and measure.
Description : Floorboard section, cab, under rear seat, right, Blazer, 39 inches x 30 inches with 7 inch flange
Pic:
[ QUOTE ]
sure looks like it...
[/ QUOTE ]
since thats exactly what I just said to myself, I'll second that... the measurements sound about right I just chopped my floors out for diamond tread panels.
[ QUOTE ]
I've liked the Diamond Plate Idea for a while...got any pics??
[/ QUOTE ]
Not yet /forums/images/graemlins/frown.gif Still getting the garage cleaned out so I can get th truck in the garage! the weather caught up with me /forums/images/graemlins/tongue.gif
Goodmark enterprises carries them also.
for some reason they are like $90, seems well overpriced, but i guess when not everyone makes the piece, you can do that.
has anyone tried these yet? need one for the passenger side of my '90 and these look like an option as long as they arent cheapy thin stuff
I thought it fit like FU*K%N SH#T!!!!!
I tried to use one in my 87. The 86-91 foor boards are different than the 85 older. On the newer trucks, the seat mounts are recessed into the floor pan. On the replacement, They are raised like the older floors. Not a problem If you have the older floor. Also, The hole for the passenger seat rear catch (which mine didn't have!) doesn't have enough meat to support the catch. my fllor came with the hole, leaving me a gap to try and fill. The lip that folds down to meat the rocker rails was WAY off. We had to flatten the lip out and use some other scrap to put it together and have a lip to weld the edges with. We managed to make the drivers side piece fit (not well) It also didn't fit to the front floor section they sent with it. I sent it back. wasn't worth the money!!
/forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
I would have been ALOT better off just using a sheet and make my own!!
I totally agree, had similiar trouble installing them in my 89. Better off using sheet metal and bending it into shape. The best price I found for these pieces is through a place called Brown's in Two Rivers Wisconsin. Phone # 1-800-558-7750. Reasonable shipping price as well. The price was about the same though as quoted above. The E-coat on them is also subpar. You would have to scuff and repaint to make the last. I replaced all my floors as well as cab mounts, which you better check as well. Most of the floor pieces can be fabricated which would save you alot of money. I remember the first floor patch I did in a vehicle was using the skin off of a old olds trunk lid. Cut it out and sledged it and bent it into shape. Worked just as well.
I replaced my floor with 16 gauge sheet metal just cut and hammered it to the old floor shape. added some flat stock for extra support and welded it in. Total cost 20 bucks and it fits better then the one I sent back! /forums/images/graemlins/thinking.gif
Thanks for the info, may just try to fab something up instead, anyone make any decent front pans?
as to the olds trunk lid, I can state with experience
that STOP signs make a perfect floor pan for a 76 Olds
cutlass, bend one "ear" and it fits perfectly.... /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif then again that was a
long time ago, before I worked out my anger issues with
authorative symbols /forums/images/graemlins/whistling.gif
[ QUOTE ]
[/ QUOTE ]
I originally purchased LMC's pans. They sucked. (to thin) I ended up just buying some 1/4 inch and riveting it all in. It was a PITA to seal up all the edges but eventually got it right. The time it takes is the real pain. /forums/images/graemlins/k5.gif
[ QUOTE ]
This worked for me
[/ QUOTE ]
those look sweeet....you cut the old ones out and welded these in right, or just welded em in over the old ones? be interested in making me a set of those? /forums/images/graemlins/cool.gif
I took a piece of cardboard and make a templet. We then cut the plates out of 12 gauge with a plasma gun to fit. Because the seats recess into the pan, we cut 1/2" tube as spacers and tack welded them where the bolt holes to support it. I Por-15 the floors after cleaning up the rust and welding any cracks. The pans are just rivited in place to allow movement over the old floors (helps prevent oil canning) and so I can drill them out, remove and do additional repairs if needed. I put discriptions with each photo. It's much stronger than stock and I have had no problems. I hope this helps. It's pretty easy and cheap.
Dave
