Flowmaster 50-series with heat shields - $100.00
sorry... 2 of them, offset in, center out and they are a 2" pipe... but if you have a shop put them on they can be whatever size you need, the pipes just need to be cut off and have them welded in
If you have a shop weld them on, they are 2.5"
If you look at the flowmaster mufflers, all the internals are the same size, its just the intrance/exit pipes that are sized, give them to a shop to cut off the pipes and they are whatever size you want.
