Flowtech Afterburner Headers for a SBC $210 Shipped
NorCalTank
Anderson, California
I had these on my 78 small block 350. They provided a noticable difference in power. They were an easy bolt on as well. They are ceramic coated, there is only surface rust from high heat and rainy weather.
http://www.summitracing.com/parts/BIG-49152-1FLT/
$200 plus shipping OBO
Paypal accepted
still have these? If you do was there any cutting or moving anything to make these fit? I have a 78 and really would like these.
The only thing that I needed to do was flip one of the front shackle bolts so the head was on the inside. I think it was the passenger side. Other than that it was painless
Looks like they will according to Summit. THis is from the sites "application guide"
MakeCHEVROLET
ModelBLAZER
Beginning Year1973
Ending Year1991
Engine TypeV8Liter5.7CID350
Engine Size5.7L/350
Engine FamilyChevy small block Gen I
Engine SwapNo
Drivetrain4WD
Power SteeringYes
Power BrakesYes
Air ConditioningYes
Standard Transmission Column ShiftNo
Standard Transmission Floor ShiftNo
Automatic Transmission Column ShiftYes
Automatic Transmission Floor ShiftNo
Footnotes1 - Also available with A.I.R. injection manifold welded in place. Add suffix "S" to the part number when ordering (Not available with ceramic finish headers).
3 - Must modify stock exhaust to retain catalytic converters.
4 - Not legal for use on pollution controlled motor vehicles. Legal only for racing vehicles that will never be driven upon a highway. If you have any questions please contact your FLOWTECH dealer.
6 - Applications with oxygen sensor use reducer BIG-10105 for 2-1/2 in. 3-bolt flange or BIG-10110 for 3 in. 3-bolt flange.
21 - On 1983-84 4WD it is necessary to remove the rubber stopper below the starter.
23 - Installation requires Flowtech air conditioning bracket BIG-10042. 1979 and later vehicles equipped with short compressor, use original bracket.
58 - Will not fit angle plug heads.
