I went to summit to order my Flowtech headers for my 89-suburban http://www.summitracing.com/parts/BIG-91830FLT/ They are on back order and don't know when they will be avilable again. So i ordered the summit version. http://www.summitracing.com/parts/SUM-G9014/ . I just wanted to know if anyone has run the summit header?
My plan is to remove the O2 bung and weld up the hole and have the headers bead blasted and hi-temp coating done. I can do the welding and blasting myself, we get alot of coating work done where i work so it should be cheap.
