Fluid quantities ???
tunerautomotive
bend , oregon
1989 GMC Jimmy 4x4
5.7L TBI
700R4
NP205
What is the quantities for .....
Front diff
Transfer Case (fluid type , ATF or gear oil)
Automatic transmission fluid - just a drop pan change
Rear Diff
Changing over to full synthetics.
Rig only has 79k original miles on it.
thanx
here ya go. These are for an 87 but should be the same.
1989 GMC Jimmy 4x4
5.7L TBI
700R4
NP205
Front diff 6.5 pints
Transfer Case (fluid type , ATF or gear oil) 5.2 qts DexronII
Automatic transmission fluid - just a drop pan change 10.0 pints
Rear Diff 6.5 pints
thanx
1989 GMC Jimmy 4x4
5.7L TBI
700R4
NP205
Front diff - 80/90 - pump fluid in until it run out plug.
Transfer Case (fluid type , ATF or gear oil) -ATF-remove top plug and pump fluid in until it starts to run back out. (be sure to drain it first and verify fluid type)
Automatic transmission fluid - just a drop pan change- ATF- about 7-8qrts, i usually start with 5 qrts and then add as I go along.
Rear Diff- 80/90- same as front
thanx
good luck:whistle:
