CyberSniper said:
The 87C10 is stock down to the original spark plugs and wires. If you want to see them I pulled them out last Sunday.
The 86 Monte Carlo SS my Dad ordered from a GM dealership with such oddities as power windows but manual locks and a bench seat and was never driven nor worked on by anyone else.
The 86K10... who knows. The motor appeared to be bone stock and matched the drivetrain and all the emissions/sensors for the year so I assume it was stock. It didn't match the cab though (somebody transfered the dash metal to a 73-80 cab).
Back to your regularly programmed "beater_k20 needs to join the band" broadcast.
the 87 C10 is 100% correct with centerbolt valve covers and a 1pc RMS
there's a chance the 86 Monte SS could have been an early 86, and they were just using leftover 85 LG4s, which explains the 2pc RMS, or it could have been an early 87, early enough to still be titled an 86, which would explain the centerbolts. nothing that would explain both not being consistent for that model year. perhaps when the car was new, it was scabbed for parts temporarily to make a sale, then in order to complete the car the "incorrect" parts were installed. i have seen it happen on several occasions.
you're not sure about your K10, and as we all know, a 1pc RMS block, and 2pc RMS block share the same external dimensions. so that point is pretty much worthless.
as for joining the band, i see no reason for it. i'm just stating the facts, straight from several aftermarket parts supplier catalogs (Fel Pro, Victor-Reinz), GM parts catalogs, GMSPO and Partech, and my personal experiences over the last 15 years.
