Flywheel part #
hmatiak
Savannah, GA
Looking for any part numbers for a 6.2 flywheel. I have one off of the 350, but if im not mistaken, it wont work. Thanks.
-Heath
I have a SMF for 6.2/6.5 diesel, same flywheel, and the P/N is 14050525N
I'm not sure it's GM, but it is for the correct application . . .
is it for the 6.2/ turbo400 you have listed in your sig? if so - you'd need a flex plate. ;)
its for the sm465 that will be replacing the th400. Thanks anyway.
Thanks for the #'s ladies. should be bolting it all together this weekend and putting the k20 cab on the blazer frame.
