Flywheel size
clarkjw24
McBee, SC 29101
What size flywheel comes on a 85 4x4 dually with the sm465/205? I guess I'm going to order a zoom or centerforce clutch and pressure plate setup. They list several different splines and diams. 10.4,11,12 and 26spline and 10spline. Also is there a difference in the diesel flywheel and the gas engine flywheel or are they the same?
ive only seen a 11" and a 12" clutch in trucks, both use the same flywheel.
IIRC the sm465 is a 10 spline input.
the flywheels are differnent between the gas and diesel, not sure how exactly.
