for dollars spent
blazin_blazer
central arkansas
how come the 2.5 ton rockwells are cheaper than the d60 or the 14 bolt? i play mostly in the mud and want to run the strongest axle i can swing under my rig, and upon searching i found the rockwells cheaper than the regular axles. this seemed odd because i've seen some rock crawlers with the rockwells also. as soon as the 54'' boggers are available i plan on running them but in the mean time i will run the 53'' goodyear gp-2b's. i have these tire already they runn them on the front of the fertilizer trucks around here, with like a 84" on the rear:dunno: would i be better off saving up more money and going with the d60f and a 14bff or run the rockwells? i plan on using custom springs also but that another different story. any info on the axle will be appreciated.
and the fact they arent that much stronger... sled and truck pulls are plenty popular here, and ive seen plenty of trucks go from one ton at one pull, to 2.5s at the next, and break the 2.5s easier... the shafts are nominally stronger and you can only have ONE ratio iirc... a d60 with 35s and ctms is plenty strong, and LIGHTER
k5floyd said:
just out of curiosity how much stronger is a beefed rocky than a beefed d60
A 'beefed' rockwell with 2" axles is Stupid strong....and stupid expensive.
The reason they are cheaper is simple supply vs. demand. A 60 will bolt in real easy. a rockwell will require some fabrication. Brakes, steering, spring mounts, wheels all need to be addressed.
in otherwords gents... go one ton chevy, you can find it, buy it and run it...
yeah the axles themselves are cheaper. there is simply a lot more work to get them under a truck. especially if you want the truck "street legal"
