- Joined
- Mar 3, 2000
- Posts
- 9,123
- Reaction score
- 7,076
I put this here because the wire may be able to be used for automotive work so I figure that makes it truck related
So the other day the wife and I are leaving town and as we are turning right I see something in the middle of the road for traffic going straight that looks like it could total a rice grinder if it ran it over. So I tell the wife to stop and I am gonna move it.
It ends up being a 500 foot spool of electrical wire. So my question is what is this used for?
The wire is insulated, green in color. Looks like heavy copper wiring on the inside. Printed on the wire insulation is the following: REPUBLIC WIRE 10 AWG TYPE THHN OR THWN 600V OR GASOLINE AND OIL RES II OR AWM VW-1 SHNRES OR C-7UL TYPE T90 NYLON OR TWN 75F 187614FT1
So what is it used for? Any good for automotive? Seems pretty rigid and overkill. Worth any money?
Thanks
Thanks
)which is the same as most cheap auto parts wire that they sell (GPT), so you could use it for automotive use if you really wanted to. Good automotive wire (SXL or TXL) is rated to 120c. Solid wire doesn't transmit the current as good, and creates more heat in the process. Current always transfers along the outer edges of a conductor, thus good quality wire has more strands. More stands=more surface area=better conductivity.
