nicks
Registered Member
I have a th350/203 that I want to use the trans and mate it to a 241. I know that in the early 80s some k5s came with a 350/208 setup from the factory. My question is, from what I have found these usually had a tall adapter, is this correct? Also, is the tail shaft length the same on 350/203? If someones has a tail shaft measurement for a 350 that bolts to a 208 please post it as it would answer most of my questions. I was almost done drawing up a adapter on solidworks, when I realized some th350s came stock with a 208. I have seen tall and short adapters advertised as interchangeable between 700/208 and 350/208, yet believe that the 700 has a longer tail shaft.
