? for the ATV guys
bronc3buster842001
leadwood missouri
I need a new plug wire for mine. Dont want to give Kawaski 80 bucks for a complete coil when I just need the wire.
So where can I get just the wire or maybe an aftermarket coil.
I looked there. They dont have what Im looking for.
Quad is an 89 Kawaski Mojave 250.
I found a site that sells NKG universal plug wires. Just dont know if I can change just the wire.
some coils you can unscrew the wire from the coil, it has what looks like a wood screw that the wire screws on to, you can just get a generic wire from the auto parts store as long as it's the same type annd O.D.
heres a pic I found online
Yep, I see what you mean. All they show is the coil and wire together for about $85.
It might be doable. You need to try to get the old wire off and see if there is a way to attach a new one.
I pulled the old wire off and clip about a half inch off of it. Then put it back together and rode it all day. Mine didnt look like it had a screw inside. Looks to be just a spike.
Dont they need to be a solid core wire.
No, the carbon/kevlar type usually just has a spike that goes up inside the insulation and makes contact with the core.
might be up a creek on this one
rockymountainatv.com doesn't have it and normally they have all the aftermarket stuff
chaparral-racing.com also doesn't have it
Nothing on EBay currently
:( Unless it's something you can make, you might have to fork over the $$.
