bronc3buster842001 1/2 ton status Joined Sep 30, 2006 Posts 2,000 Reaction score 7 Location leadwood missouri Nov 7, 2010 #1 Does anyone know what the spring spacing is on the front axle. Axle is from a 76 highboy. I can get it cheap if it will work for my project.
1BEATK5 1/2 ton status Joined Dec 15, 2005 Posts 2,736 Reaction score 40 Location beaverton orygun Nov 7, 2010 #2 spacing should be the same, but highboy's have a low pinion front.
bronc3buster842001 1/2 ton status Joined Sep 30, 2006 Posts 2,000 Reaction score 7 Location leadwood missouri Nov 7, 2010 #3 1BEATK5 said: spacing should be the same, but highboy's have a low pinion front. Click to expand... Not worried if its a high or low pinion. The low pinion will work fine for what I'm doing.
Avery4jc 1 ton status GMOTM Winner Joined Oct 24, 2005 Posts 10,790 Reaction score 164 Location Fresno, Ca. Nov 7, 2010 #4 I can measure my dad's truck tomorrow if nobody chimes in first. It's a '75 Highboy. I bet Wes would know though...
1BEATK5 1/2 ton status Joined Dec 15, 2005 Posts 2,736 Reaction score 40 Location beaverton orygun Nov 7, 2010 #5 1BEATK5 said: spacing should be the same, but highboy's have a low pinion front. Click to expand... i should have been more clear. yes they are the same
bronc3buster842001 1/2 ton status Joined Sep 30, 2006 Posts 2,000 Reaction score 7 Location leadwood missouri Nov 7, 2010 #6 So they should be 31.5''
thatK30guy 1 ton status Premium Joined Jan 12, 2001 Posts 32,580 Reaction score 541 Location . Nov 8, 2010 #7 Yep, same as GM's.
