because their hub is leaking, even after a new seal ... install tip: The stupid piece of metal they give you to install is waaaay too short. Billavista used a handy piece of 3" exhaust handy to use as an install tool, but I didn't have any, nor any 3" PVC pipe, which woulda been my next choice. See
http://www.pirate4x4.com/tech/billavista/SpeediSleeve/index.html
I discovered, however, that a roll of duct tape fits perfectly over, is just still enough to hold the sleeve but soft enough it won't mar it, and can be tapped into place with a rubber mallet very nicely.
End result is a niiice clean surface. Seeing my inside brake pad was soaked through with gear oil
I hope this does the trick.
Duct tape: the handy man's secret weapon!
-- A
-- A
Usually, if there's a special tool for doing a job I probably have one.
