If you've replaced all the braking system components (calipers, pads, lines, flushed, MC, etc) and still have a problem with your truck pulling when you slam on the brakes, try replacing your drag link and/or tie rod.
I replaced my drag link which took a TON of slack out of the steering, and replacing my tie rod fixed my pulling/wandering under hard braking. As far as I can tell the tie rod was worn out to the point where it would allow one wheel or the other to kick out to the side resulting in unpredictable braking when the weight transferred to the front end.
