Easy answer: 14bsf. 33 spline vs. 31 spline = no brainer. Yes, you can get em in 6 lug (I did
). 6 lug axles aren't as common as 8 lug, and it will be found under a NBS truck so you will have to move spring perches and shock mounts. As for cost, I paid $140 for mine. Aftermarket support? Lockers? Well, you can get axles from Superior, and available lockers include the Detroit, ARB, Eaton E-locker, Powertrax's Lock-Rite and No-slip, and of course posi's from Eaton and Auburn. The lockers aren't any more expensive than the ones for, say, D60s and other similar sized diffs.
C-clips... yup, it uses C-clips. BFD. People consider it inferior to externally retained axles, but that's not really the case. Let me explain: I have seen externally-retained axles (i.e. 9 inch, D44) break, and while the axle doesn't slide out the vehicle is NOT driveable. The broken axle flops around inside the tube, and as a result the tire wobbles and the axle makes a racket. The axle ends up cocking the axle in the bearing which is something the bearings definitely aren't built for and won't tolerate for long. You can simply put disk brakes on a c-clip axle and it will be retained if the axle breaks. It will still do all of the bad things that the externally-retained axle will - that's just a limitation of SF axles. If you want to be able to drive on it after you break an axle, get a full floater. C-clip axles do have one distinct advantage oner externally-retained axles - the axle bearings have a higher capacity for a given tube size. This is because the C-clip axle uses the shaft itself for the inner race, which means it can be a larger diameter and the rollers can be bigger.
Here's some food for thought: The smallest diameter on a 14bsf shaft is 1.400", just behind the splines. The splines are 1.420", and about midway the axle necks up to 1.700". According to Pirate 4x4 (
http://www.pirate4x4.com/tech/billavista/14b_bible/index.html, scroll down about 1/3 of the way) teh operating diameter of a 14b full floater shaft is 1.351". This means that, assuming the shafts are made of the same material (which they are), the sf shaft should be capable of handling as much torque as the ff. Some will make the argument that the ff shaft doesn't have to support the weight of the vehicle (which is true),, but they forget that the part of a sf shaft that supports the vehicle is 1.700" in diameter. You can look at this as being a 1.700" .150" wall tube supporting the vehicle with a 1.400" shaft transmitting torque through the middle, i.e. there is enough extra meat that loading capacity isn't a problem. This will be heresy on this site, but I bet the sf shaft can handle as much torque as a ff. The difference, of course, is that if you do manage to break the shaft you can still drive the ff
OK, long winded. Well, I'm going on a hunting trip in the morning, so I won't see any replies to my heresy for a week. Feel free to flame
