Been looking to pick up a little Ford 9n for a while now and I ended getting one at an auction. It's far from perfect, but it runs good. I know me and how my thoughts are running already, I'm gonna need a build thread.
First 2 major things will be getting the 3-point to work and it will need a 12 volt conversion. It needs the 12v because it already has a 12v battery but nothing else has been changed which means it's not charging and the points are getting more voltage than they should. The 3-point is likely an easy fix, it's very common for the valve to stick. Also gonna need to find some better rear tires.
Beyond that I'd like to pick up a couple implements for it, a blade and an auger. I also want to make a few accessories for it myself.
