ford dana 60
blazerboss 85
Banned
grass valley CA
i just get a free dana 60 from a guy it came off a 2001 f350 its a driver side drop and it has ball joints does anyone have any comments or info about this axle that would be good for me to know and also how much do you think i could sell it for i want to find a chevy dana 60
I know they're in our shop on a regular basis needing ball joints and/or unit bearings replaced. I've also heard that a lot of those trucks don't actually have a dana 60, it's a 50 or something.
x2 on the info listed above. and yes dana 50 . only way to get a true 60 in them in those years was dulley so i have heard.
if me sell it on evilbay or craigslist and take the money and buy a chevy or dodge 60 .
'99-02 SRW Superduties got D50's, the duallys got D60's.
'03 and up is all D60.
If the axle is from an '01 its either a D50 or its a dually front end. The dually front end makes it not worth much.
The biggest downfall to a '99 or newer superduty axle is that it uses a metric lug pattern which means you have basically no choice in wheels. You can use stock Ford wheels or buy SUPER expensive aftermarket wheels and even then you only have a few to choose from.
Its pretty common to see Superduty 60's go for a few hundred bucks because, well, they're not that good.
I'm not trying to argue with anyone, but alot of misleading info is being posted. ALL F350's SRW/DRW had 60 fronts, in '03 Ford stopped making the Dana 50 in their F250's and Excursions. Essentially, a Dana 50 is a 60. The only difference is the ring and pinion, and neck down inner shafts. The ring gear is just a fraction bigger than a Dana 44. ALL other parts are the exact same in the Super Duty years, i.e., knuckles, hubs, outer shafts, etc. The housing looks exactly the same, until you pull the diff cover off.
The wheels are metric, 8x170 bolt pattern, '05 and up are also factory coil sprung and use a different offset than previous years. Wheels are not any more expensive than your standard 8x6.5 bolt pattern, if you don't want different bolt patterns F/R look into the Sterling 10.5 rear end from the same truck. (comparable to a GM 14 Bolt in strength) Also, these axles are called super 60's, they have 35 spline inner and outer shafts from the factory.
The weaknesses are the ball joints and unit bearings, but it is like everything else, mechanical. It's going to break eventually. If left neglected long enough kingpins will get loose and wear out too, causing some serious death wobble and drivetrain issues.
So I'm curious, is there any real difference between a F250 and a F350 SRW, especially in the '03-'04 model years?
Nothing, for 03-04, they're 60 fronts, Sterling 10.5 rear, leaf srung F/R. The only real difference is the rear leaf springs I beleive. The 350's have a stiffer leaf pack.
In '05-07 they went with a coil sprung front suspension setup. In '08 the truck was redesigned, but basically the same drivetrain, minus the junk 6.0 Powerstroke, instead they introduced the diesel guzzling 6.4 Powerstroke:doah: Biggest mistake Ford ever made was getting rid of the 7.3, the engine was tried and true, I have seen many of them with over 300,000 miles on the clock and stick chugging along.
Changed the gears last year in a 03 four door f350 with diesel and had a d50 front. put 4.30's in there for towing, no 60 for sure cause i tore it apart. Srw. It towed my truck from lake tahoe area to the bay area with no problems.
Did you buy the truck new??? Was it rebadged as a 350??? Did someone swap your 60 into their 250??? The reason I ask, I had an 01 SRW F350, went from 3.73's to 4.56's and I know for sure, did it myself, that it was a 60.
Good friends truck and he bought it new and uses it to tow a triple axle toy hauler and it works fine and it has a d50 front and in being in California might have something to do with options and how it was sold. Thought he got robbed as well.
