oneofthefewbmx
This came out of a running, driving 1991 F-350 4-door diesel single wheel. The injection pump took a dump, so the truck is being parted out.
Axle is in good shape, even has good rotors and pads. 8x6.5 bolt pattern. 3.54 gears, I assume open-diff, but I will check when I drain the fluid and take pics.
Comes with EVERYTHING! Sway bar, brakes, tie rod, drag link, sway bar, lockouts, U-Bolts, plates, lug nuts, track bar, and even shock towers (good for your SAS)!!
I am going to clean the axle and strap it to a pallet. It will be ready to ship.
$1500 shipped!! (you guys on the West coast will make out like a bandit on this)
PM or call / text 254-220-68O5 with any questions.
Thanks guys!!!
Thanks guys!!!
