- Joined
- Mar 3, 2000
- Posts
- 9,121
- Reaction score
- 7,073
1978 Ford F-150 NP 205, with standard transmission. I need a new speedometer gear, which rides on the rear output shaft of the 205. I haven't been able to find one so far. There were a couple used ones on EBAY but condition didn't look great. This is a white in color Nylon type gear, inside is splined and has rollers that ride on the output shaft. Should be 7 tooth, maybe 8. The teeth that intersect with the gear on the speedo cable, if you lay the gear down those teeth start from the lower left and go diagonally to the upper right. on the edges of the diagonally splined area there is also a smooth area around the outer circumference if that makes sense.
I have found a blue gear for an NP 208 that looks similar but they don't have any dimensions so I can't tell if it would work, I put in a call to a couple places waiting to hear back, but thought I would post here in case someone has an idea where to get one.
. . . Guess i got GOLD here . O.e.m. used should be better than aftermarket .
