The Mog-9 axles I'm building use an 8-Lug conversion setup that uses Ford disc brakes and rotors.
I was told to locate parts matching this description:
1995-97 F250 Heavy Duty 4WD 3/4-Ton Pickup
I believe all of these trucks would have been disc/drum setups so I'd be looking for the front brake parts, correct? Also, I was told that there might be some variations depending on the GVW of the truck so I was told to select whatever parts had the highest GVW rating. I think this would be either 8600 or 8800Lbs.
The rotor I've found online is this:
Ford OE # YC3Z-1V125-AA (or)
Bendix P/N 145055
This is a 8 on 6.5" lug pattern, 12.953" diameter, 1.185" thick vented rotor.
There are some other choices that look similar but the diameter and thickness is slightly different. Can anyone confirm that this is the correct rotor for the vehicle in question?
Also, for extra credit: Can someone help me locate the correct part number (Ford or Bendix) for the matching caliper that goes with it?
I'd like to start with a stock part, then once I'm sure I have the application correct I can also look at some of the aftermarket offerings from places like EBC Brakes, etc. I'm not sure if the rotor height will change, or if the mounting flange or caliper thicknesses will be different, but if I run into clearance issues I may have to spend more time looking for alternatives.
Bendix P/N 145055
