Ford Question, yeah I know, brake help please
sled_dog
1 ton status
Austin, TX
Alright I'm Ford stupid, how do I remove these calipers? It looks like they could split apart, you can kind of see it in the third picture. But there is the little bolt I already removed in the second picture that seemed to lock that plate in. Looks like if I pound that plate thing out the caliper will come out but it doesn't want to budge. As usual I don't want to make something move that shouldn't /forums/images/graemlins/wink.gif
You are correct in the second picture....above the arrow there is what looks like a little "I" beam. Drive that out and it will fall apart.
Edit* ok with all that rust it ain't gonna fall apart but it should /forums/images/graemlins/wink.gif
the next guy will have it easy, gonna clean up everything and put in new parts
Aren't those two big bolts holding the caliper halves together? If memory serves they are.
Sled dog, did you remove the little set screws that the red arrow is pointing at?
They are very weird brakes but you'll figure them out. Do yourself a favor and buy yourself a brake hard parts kit when you replace them rusty calipers.
there was some big bolt in there not a set screw /forums/images/graemlins/dunno.gif, I removed it just before taking the picture. half of it was ground away I guess to clear rims.
Yes, the two big bolts hold the caliper halves together
[ QUOTE ]
[/ QUOTE ]
It takes like a 9/16" socket....that holds the "I" beam.....I'm pretty sure thats the set screw Kert is talking about. (about 1" long thread with 60* bevel and then the head)
yes, take out that 9/16 bolt, then hammer out that "i-beam" remember when i did mine at ur house? same idea, just mine is smaller.
The set screw that retained my I beam peice was removed with an allen key. Little different design I guess but this is why I referred to it as a set screw.
First time I looked at those brakes I thought what in the hell was this guy (ford engineer) on?
