Where are you mounting your Furd shock Towers when you have AC? I have been searching for an half hour and cant find any pix. There is a lot of info but it is so old the pix are deleted.
What are you having problems with?
) I have my York in the same area, and they're not even close, IIRC...ssped said:1st they are the older style steel towers. On the rt side one it is under the AC box! I can not go any higher on that side unless I move it forwards. I need Pix of that side with these installed.
ssped said:does the top of that sit in front of the AC box? It is a dark picture.
Which writeup? I'm about to do this and wouldnt mind reading up some moressped said:I know in the write up they cut a few inches off the bottom of the tower but it does not look like I will get much more travel out of it? I will have to go look at it again.
Sweet thanks, I looked around there but couldnt find itssped said:
. ssped said:check out what they look like in the picture but they can be obtained from the dealer for under 25$ for the pair. I paid 8.50 each(employee deal) they are going to tell you they are discontinued but they can still get them.
Dafey said:Do fords have a cheap catalog like , LMC for Chevy?
lochenjons said:Are the shock towers normally riveted on the furd trucks or are they bolted on? If theyre riveted on thatl make it hard (read:impossbible) getting them from the pick n pull. Is that why everyone says to get them from the dealer?
My time wasn't worth the $$, and the Ford dealer is a LOT closer than PnP
Question for ya, how much lift is on your truck, and how are those shocks working out for you.sandawgk5 said:Ed,
Here is my writeup on my ford towers. They are the new style cast ones but you can see in the pics where they are in relation to the ac box.
http://coloradok5.com/forums/showthread.php?t=165893&highlight=ford
Ira
Jason4x4 said:Question for ya, how much lift is on your truck, and how are those shocks working out for you.
