Muddytazz
1 ton status
For those of you that have done it, how did you figure out how much tower you needed for the shock travel?
What is the benefit of the ford shock towers? Just a pre-made mount? Where are you guys getting them and how much do they cost?
IMHO, I don't think mounting the shock tower then choosing shocks is the best way.
I have 52s up front, and the pressed towers..but the steps should be the same. Before I mounted anything I measured from the spring to the frame at static ride, then full droop and finally compressed to figured where/if I needed bump stops. I figured the amount of travel I had and ordered shocks - 15" Doestch. I then figured the shock length fully ext/comp and decided what comp/droop i needed. For me it was ~4-5" compression, the rest droop. Measured the towers and a little math then mounted.
-JC
...Just a pre-made mount?
...how much do they cost?
