owenst7
Off a ~75~80 (+/-) Ford E-series van. They are 1.75" drop, so they just barely clear the frame with the castle nut. Part number is D5UA-3590-CA.
They will need to be reamed out to fit ES2234/ES2233/ES2010 (TRE), so obviously they need to be reamed to fit ES2026/ES2027 (DLE) too.
This is at ride height with stock K5 52" rears up front with the axle in stock location. I still have about 4.5" of bump travel. With the Superlift arm, I would only have about 2-3" of room, which would make things real tight trying to fit hi-steer and move the axle forward.
If there's enough interest, I may be able to afford to buy a reamer and ream them out for drag link ends. I can also dig up 2 wheel drive sector shafts, so you'd have all the steering box parts you need for crossover.
EDIT (better measurements):
Axis-Axis length: 6"
Major Diameter: 0.74"
Minor Diameter: 0.62"
They are 1 3/4" drop.
This is mine which is reamed out to the dimensions of ES2026/ES2027 (GM drag link end). Figured some people might like to see how much material is left after reaming them out.
