Yeah,I know,this is a GM site...but I thought some of you may be interested to hear this one...................................................................................Anyone familiar with the later Ford 5.4 and Triton V10 engines know all about their tendency to spit spark plugs out after 80K or so--the heads had only 3 or 4 threads in the spark plug holes,and they often loosened up and blew right out of the heads...leaving only the ignition coil to hold them in ,if they had no separate coils,the plugs would blow out like bullets......................................Ford is aware of this problem,but has yet to issue a recall,even a "silent" one,and trucks that do this either need new heads--or have special pinned inserts installed in the heads,to the tune of 500 dollars per cylinder!--a local company comes to the Ford dealer ner me often ,that has a service van with a special machine that can supposedly install the inserts without engine removal or head removal....................................................................Yesterday a friend was doing a tune up on a later Ford Expadition,and the rear most plug on the passenger side refused to come out--he couldn't seem to get the plug socket to fit down deep enough in the "well" after removing the coil,and he thought perhaps the plugs may have had 9/16" hex,as some newer Fords did,but the other 7 came right out with the 5/8" socket--he even resorted to grinding down a socket hoping it'd fit deeper into the well,but that failed also...finally he was able to grip the plug with another deep 5/8" socket and remove it......................what we saw next baffled us both!!..............................................................................................There was an Autolite "HT-1" "Revolution" spark plug with a 1/2" hex,threaded into what looked like a anti-fouler,that had a 5/8" hex,and the plug had a ground eletctrode that was welded on both sides of the plugs threaded shell,like a "U",and it had weird coarse threads!..and there was some kind of self tapping heli-coil type of thread insert threaded over the "non-fouler" looking adapter dewhickey....if my friend knew the plug was 1/2",he may have been able to get it out without having the non-fouler and heli-coil thing come out too,but it may have unscrewed like it did anyway.............................................................................................Now he had to figure out his next move--a quick call to the Autozone down the street shocked us--they not only HAD 12 of those HT-1 plugs in stock,they knew about them being used somehow as a "fix" for the stripped plug holes....!!!..........................................................................................Weirdest looking spark plug I've seen in anything in my 35 years of auto parts dealings...
...you cant "gap" them,I guess they are "lifteime" once installed??...all I know is I'd never buy a Ford with those engines--nothing but garbage!!.....................................................
