forget stacked frames. Im making a frame out of 100% weld.
mini airbags between the stacked frames as well as the body and frame. Like floating on a cloud of.....umm AIR!! :haha:
Personally I would use a bunch of bolts and nuts and screws I have laying around to save on the welding rod and wire. :D
Use the leaf springs for body mounts.
In the middle of the frame, cut it and put it back together using a huge bearing so that the rear of the truck could rotate 180 degrees for ultimate flex. Move the fuel tank up under the hood and disconnect the rear brake lines.
