found a few problems with my xj shaft please help
sweetk30
Back to play nice .
in the back of your brain
got my plow truck back out for some driveing time to run some stone to a buddy and few trash runs from garage clean out.
well found a smoked lf 60 caliper and hoses look crapy. so time for new hoses and calipers.
but big problem is steering wheel off a bit and has up to 15* of play till movement.
well looked under hood and the slip section of the jeep shaft is wabbling all over tons of slop big time.
what have you guys found over time on them or have you seen this happen before. i need to fix this soon and dont have the stocker anymore for temp. most of the junkyard ones are frozen ujoints and no good around the rust belt here. got 2 last time out of 7 shafts.
