T
TankerCadaver
Guest
Folks,
I think I finally found the Blazer I've been looking for. It's not a CUCV but it IS a diesel and the price is right (or at least I think so) and it's local.... whew.
1982 K5 Blazer Diesel w/ the 6.2L
135,000 miles (!)
Rust is not bad... the passenger fender-well has a hole in it and there is rust in the passenger rocker panel. Other than that any other rust is minimal. Frame looks great too.
The owner claims he hadn't started it in a month or two when I looked at it yesterday. It started up fine, very fast really. It wouldn't idle without a little throttle input. He thought there was a cold idle solenoid or something that wasn't working right.
Any thoughts on cold idle issues?
It ran a bit rough at first. He was thinking that maybe one of the injectors was clogged, stuck, lazy, etc.
Any thoughts on rough idle or stuck injectors or the like?
With some throttle input, holding the RPMs steady the engine idled and ran at higher RPMs very smooth... hardly any movement or vibrations.
I did notice the Glow Plug Light came on periodically while the engine was warming up. He thought this was normal and indicated that this also occurs when the batteries are very low on juice. Sounded a little weird to me but I have not owned a beast like this so I wouldn't know. The batteries were dead and required a boost from some portable battery boosters.
Any thoughts on glow plug light coming on periodically?
I thought I only saw one alternator... do just the CUCVs have 2?
Well, that's about it, everything else on the rig was fine, just a bit dirty and neglected a bit.
I would certainly appreciate any help you can provide this weekend. I'd like to give the guy a call on Monday to let him know what I've decided.
Thanks!!!
Tank'
135,000 miles (!)
Thanks!!!
Tank'
