OrngK5
Registered Member
Thanks for the help again CK5, and I found the problem with the brakes. I checked the reservoir level and it was low, had a family member pump the brakes a few times and sure enough, air was bubbling in the MC. I followed all the hard lines, no leaks. Finally I removed the right rear wheel since there was some sort of grime build up, and confirmed my suspicion. Brake fluid was all over the inside of the drum, all over the shoes and lining, and all over the drum brake mechanism itself. I can't drive it now since it technically doesn't have brakes, and I lack the tools to remove the flange covering the drum brake mechanism. For S&G's I looked at the front discs, and the rotors are starting to rust on the edges and the calipers are a mess themselves too.
My questions are: What likely happened in the rear drum to cause a large brake fluid leak? What I am looking at in repair costs for a complete brake system overhaul, i.e.; new shoes on all brakes, fluid, new lines, new rotors, new calipers?
Thanks again as always!!
Cliffs:
Had brake problem
Removed right rear drum, found massive brake fluid leak
Front disc brake rotors have major rust build up, calipers too
What happened?
How much to repair?
Cliffs:
Had brake problem
What happened?
How much to repair?
!! Are you in town today?
