Finally pinpointed the diesel leak in my '82 pickups 6.2..the rearmost drivers side injector weeps ever so slightly from the seam between the two halves of it,takes maybe 20-30 seconds for it to form a drop,that falls directly onto the hottest part of the exhaust manifold (of course!)...after a 5 mile drive,you'll see smoke coming out from under the hood...I thought at first it was brake fluid dripping from my master cylinder,that too weeps from the rear where it bolts on,but of course,that would be too easy a fix......................................................................................................Since my injector lines are crusty and the hex where you'd put a wrench to unscrew it from the injector goes is pretty rotten,I doubt it will loosen without stripping,or worse,breaking the line itself...I am going to try using J-B Waterweld putty on the seam after a good wash with brake cleaner and pray it will seal it up and last thru the winter,because I'm not up to replacing the injector lines now,though I do have some spares,and a parts engine I can rob an injector from..I dont have a 30mm deep socket either..............................I'm wondering if anyone else had an injector leak there,and if they were able to epoxy it and get by for awhile???.............................................................................................I'm getting sick of the 6.2,its been a good engine,but I dont like being a diesel mechanic--gas engines I'm more familiar with and I'd actually prefer one over a diesel,with fuel so costly now,and I'd also not miss the hassles of cold starts,busted off glow plugs,etc...If I knew someone with a carbed straight six I'd trade them straight up...but the truck is to the point its not really worth putting an engine in,or doing all the work to the 6.2.....with my moms health getting worse,my days here living with her are numbered and I'll likely not need a plow truck after she is gone,plus I'm about broke and cant afford to have anyone esle fix it for me....................................................................................................................................................................................................................I have a J-code intake I could swap into the 6.2 along with the injector lines,but it also needs the oil pan replaced,both exhaust manifolds are rotted to death,and the oil cooler lines are the next thing that'll rot thru and leak...it'd be a hell of a lot easier to repair all that with the engine OUT,but I cant do it now,I feel like I have cracked ribs just from leaning over it under the hood for 30 minutes the other day....figures this would happen right when I need the truck most to plow...
...anyone else think the J-B will work on the injector ,at least temporarily??..
